Ta 152 MW 50 and GM-1 Commands
JSW27
Is there a programmable joystick command in FSX for the combined MW50/ GM-1 on the Ta152?
Re: Ta 152 MW 50 and GM-1 Commands
no, not directly since it's a custom made variable.
If you have FSUIPC you can assign a key using a LUA script using the method described here:
http://www.classics-hangar.de/phpBB3/vi ... f=17&t=609
The variables to use are these:
The Sonderstoff electrical fuse in the right panel:
L:sonderstoff
The Notleistungs activation switch in the left panel:
L:notleistung
The MW50/GM1 selector switch:
L:notwahl
L:sonderstoff
L:notleistung
L:notwahl
