IFR Propellor backwards blade?
pilottj
Post by pilottj »
lol I was working on a repaint and was wondering why the propellor looked a little bent from a distance...looking closer on the IFR version...
Does one of the propellor blades have to be flipped so the leading edge is going the other way? :)
Cheers
TJ
Re: IFR Propellor backwards?
Oups! I will fire all my beta testers! :twisted: :lol: :mrgreen:
Serious, thanks for the report, I didn't catch that, DOH!
pilottj
Re: IFR Propellor backwards blade?
Post by pilottj »
LOL maybe thats why the prop failed at high RPM :mrgreen:
Good pickup!
Mathias Pommerien wrote:Oups! I will fire all my beta testers! :twisted: :lol: :mrgreen:
I'll volunteer ;)
bstolle
Post by bstolle »
talking about 'backwards'
Can someone confirm that the elevator trim and flap wheels are rotating in the correct direction?
With all planes I've flown so far 'forward' means nose down (and flaps up) but maybe the Germans had it backwards in WWII like the Italiens the trottles...
I had to double-check that myself, Bernt, that's actually how it is.
The logic is that when you trim the nose down, you actually trim the tail fin up
pilottj
Post by pilottj »
just a very minor texture mapping note, I think the prop blur texture for the back of the propellor is mirrored to the front texture, not a seperate one. ie if you have a stripe on the front of the propellor and want it to show in the blur, it will appear on the back of the prop blur too.
Yes TJ, that's correct, front and back of the blurred texture are the same.
That's how it's done to save drawcalls.
pilottj
Post by pilottj »
Sounds good lol...I simply added a stripe to the back side of the prop. Personally I like being able to see the propellor arc is from cockpit...then I know not to raise the tail too much on takeoff :mrgreen:
bstolle
Post by bstolle »
Mathias Pommerien wrote:I had to double-check that myself, Bernt, that's actually how it is.
Ah ok, thanx a lot for confirming that :)
