GPS for the FW 190A possible?
william thompson
Post by william thompson »
Greetings everyone, I really enjoy cross country flights in the 190a, but I find vfr navigation is difficult at 400 kph, and I wonder if it is possible to add a GPS to the aircraft? It would be a great help, Best Wishes, william thompson
Re: GPS for the FW 190A possible?
Hey William,
sure, you can add the default one or any other third party gps as a popup window to the panel.cfg.
Here is an example from the Fw190A-1 utilizing the default gps.
You would just add the parts highlighted in red.
The window toggles with Shift+3.
[Window Titles]
Window00=Main Panel
Window01=Radio Stack
Window02=GPS
[VIEWS]
VIEW_FORWARD_DIR=4.000, 0.000, 0.000
[Window00]
Background_color=0,0,0
size_mm=500,243
window_size_ratio=1.000
position=0
visible=0
ident=70
window_size= 0.400, 0.324
window_pos= 0.000, 0.040
gauge00=ClassicsHangar_XMLSound!FBGS_XMLSound, 12,1,5,5
[Window01]
Background_color=2,2,2
size_mm=312,298
position=8
visible=0
ident=RADIO_STACK_PANEL
zorder=3
gauge00=Bendix_King_Radio!Bendix-King Radio Audio, 0,0,312,62
gauge01=Bendix_King_Radio!Bendix-King Radio Nav-Comm 1, 0,62,312,118
gauge02=Bendix_King_Radio!Bendix-King Radio Nav-Comm 2, 0,180,312,118
[Window02]
size_mm=456,378
pixel_size=456,378
position=2
visible=0
ident=GPS_PANEL
zorder=4
gauge00=fs9gps!gps_500, 0,0,304,252
william thompson
Greetings Mathias, and many thanks for your help, which I appreciate very much, Best Wishes, william thompson
