It's just that I have a problem. When the plane is on the ground, it vibrates a lot, which is irritating. I have tried a reinstall, but it didn't help. The vibration didn't happen before, interestingly. I have the 1.22 version.
The plane is vibrating when on the ground!
kristenburnout
Hi!
FIrst, I have to say: Exellent Fw-190! it flies so beautifully!
Re: The plane is vibrating when on the ground!
Welcome aboard!
Please read here, I think that covers it:
http://www.classics-hangar.de/phpBB3/vi ... f=12&t=136
kristenburnout
Thank you for your quick reply! I acctually found out that limiting the fps to 33 instead of 36 took care of the problem. Thank you, i am off to fly some FW!
Yeah, FSX is a weird beast at times.
For what it's worth, it's always a good idea to set max fsp to something divideable by 2 or 3 relative to your monitor refresh rate.
For instance if refresh rate is 60Hz, set max fps to 30 in FSX.
