I own the FW190 Early Variants (V2) for quite a while but the above showstoppers like suddenly completely locked Tailwheel (or completely unlocked as well) , the impossibility of a manual startup (sometimes possible sometimes not) or a roaring engine sound after switching through views made me uninstall the bird although I thought that it was a very fine peace of art !!!
Now I installed the FW190 again and all the quirks came back, but only sometimes
After trying around a couple of days I noticed as soon I switched into 2D-Panel view the tailwheel kept being locked and i was not able to start the plane manually (ctrl-e only).
To make it short I opened the resp. panel.cfg and commented the gauges out of the 2D-panel-view:
[Window00]
Background_color=0,0,0
size_mm=1280,960
window_size_ratio=1.000
position=7
visible=1
ident=MAIN_PANEL
window_size= 1.000, 1.000
window_pos= 0.000, 0.000
no_luminous=1
zorder=0
view_window_rect=0,0,8192,6144
//gauge00=ClassicsHangar_XMLSound!FBGS_XMLSound, 12,1,5,5
//gauge01=classics_hangar!ch_fw190a4, 6,1,5,5
//gauge02=classics_hangar!ch_fw190a4_2, 1,1,5,5
Now the above quirks seem completely gone. Everything seems to load fine from the start, no need to reload user aircraft i.o. to make some systems work. No 'sudden' and unwanted tailwheel locks, no startup problems and no sound issues after switching through views. But I'm still testing though.
Best regards,
Mike.
