I've revised my SoundMod v2 and it expanded with a proper cone configuration. To download via FlightSim click on the image please.
And because an real aviation veteran is at war with an old joystick and the cool flight model from Mathias, he has spiced up the old lady for a bit.
Here are the values from my Aircraft configuration file:
Code: Select all
[flight_tuning]
cruise_lift_scalar=1.00
parasite_drag_scalar=1.00
induced_drag_scalar=1.00
elevator_effectiveness=0.80 //default 1.00
aileron_effectiveness=1.30 //default 1.00
rudder_effectiveness=1.15 //default 1.00
pitch_stability=1.10 //default 1.00
roll_stability=1.20 //default 1.00
yaw_stability=1.05 //default 1.00
elevator_trim_effectiveness=1.00 //default 1.00
aileron_trim_effectiveness=1.00 //default 1.00
rudder_trim_effectiveness=1.00 //default 1.00
p_factor_on_yaw=0.70 //default 1.00
torque_on_roll=1.00
gyro_precession_on_yaw=0.70 //default 1.00
gyro_precession_on_pitch=1.00
