Problem with the "Vordruck-Pumpe"
i noticed this bevor, but i just didnt thought that much about it.
When you pull on the "Vordruck-Pumpe" you should do that a couple of times, as the manuel says, until the pressure is high enough.
Ok but somehow the pressure keeps climbing if your just hold your mouse-klick on the "Vordruck-Pumpe".
Is this a limitation of the FSX or a Bug?
User avatar
bmd
Re: Problem with the "Vordruck-Pumpe"
Post by bmd »
Hello kleineMax,
I do not know if the effect that you have described is a real one, but now I use it during the engine start sequence. So thank you for pointing out this effect.
Have a good day
Benoit
Oh, I didn't know that it was a compressor-like lever! :lol:
Will look into it.
Since we're probably done with the more serious things I'll now "collect" reports and adress all remaining things all with one patch, so it may take a bit.
Yeah, keep it slowly adding. The plane works, so everything is cool.
