				slow flight, rudder roll etc
				Posted: Fri 17. Jun 2011, 15:22
				Here's a cool youtube video of a stang. Shows how nicely an aircraft rolls at low speed by just using the rudder.
http://www.youtube.com/watch?v=fK0AGh37 ... re=related
Initially he demonstrates the drag bucket thanks to the laminar flow wing.
He then uses a turn to increase drag and slow the aircraft down.
When they are slowed down notice the comment on how heavy the controls are when they are out of trim.
Note the use of rudder to roll the aircraft instead of aileron at low speeds.
Last note how even a gentle stall break can cause a visit of the upchuck express for those not used to less than 1g
				Re: slow flight, rudder roll etc
				Posted: Sat 18. Jun 2011, 19:20
				by pilottj
				Hey Mathias,
Any idea what the max demonstrated crosswind component for the 108?  If I recall in the 172 it was around 15-20kts...I'd have to look at the POH.  I think most planes of this size had similar crosswind limitations.  My flight instructor had told me to remember that these published limitations were established by very experienced company test pilots...not low time students
  Even now with some hours under the belt, I still am wary of high crosswinds...they can be very exciting
If crosswind landings are tricky in the 108, I can't imagine how hard they would be in a BF-109 with taller narrower gear and less visibility.
				Posted: Sun 19. Jun 2011, 15:47
				by olderndirt
				Mathias
FYI - after messing with my control and realism settings, here's what works for me with an X52.  Realism - all three, general/torque/pfactor, all the way to the right.  Controls - deadzone 20% and the three axes all the way right.
				Posted: Mon 20. Jun 2011, 11:19
				pilottj wrote:Hey Mathias,
Hi TJ, those data is nowhere available in the period handbooks or in the new test data of D-EBFW.
I would have to ask Greg what his magic glass ball told him (DATCOM and Roscam maths).
				Posted: Mon 20. Jun 2011, 11:41
				olderndirt wrote:Mathias
oldendirt, glad that you got it sorted!
