Hallo, Mathias!
The new Taifun is brilliant! Thank you for this pearl! When the new patch is coming, I had to dear to make one suggestion.
There is one tiny inaccuracy concerning the landing gear struts. In the real plane, they are tilting (not much, but anyway) forwads.
In this virtual Taifun they are tilting slightly backwards. I know, this is a very little detail, but it has rather big influence for the overall look, when
looking the plane straight from the side. Could it be possible to correct this little "big" detail in the forecoming patch or in the future?
Thanks once again!
PS. Waiting eagerly for Stieglitz by the way!
Position of the landing gear struts
Re: Position of the landing gear struts
Thanks for the headsup, Flettner.
That should be doable, not with this patch though.
Flettner
Vielen Dank, Mathias!
I´ve been on a short holliday trip, and read your promising answer today.
Every time, when coming to land in hard crosswind, I´m a bit scared, that the
gear will collapse because of those backwards leaning legs
It´s conforting
to know, that there will maintenance to come!
Hals und Beinbruch!
Hals und Beinbruch!
