Update Information!
"Dora" Support Forum
Update Information!
There is a hotfix available that fixes FSX crashes some users experience and also fixes some errors found in the payload manager configuration files.
This hotfix is mandatory and should be installed even if you don't experience CTD's
To receive the hotfix click on "Start/All Programs/Classics Hangar/Fw190D - Ta152/check for Updates",
download and install "Hotfix 1".
Es ist ein Hotfix erhältlich, der Probleme mit FSX Abstürzen behebt, die einige Benutzer berichtet haben.
Außerdem werden einige Fehler in der Zuladungs-Konfiguration behoben.
Dieser Hotfix sollte auch dann installiert werden, wenn Ihr FSX stabil läuft.
Zum Herunterladen klicken Sie auf "Start/Alle Programme/Classics Hangar/Fw190D - Ta152/Nach Updates suchen"
Re: Update Information!
Update:
The installer is now updated.
The Hotfix is only required if you downloaded the product before 28.12.2013 off the Classics Hangar Shop
Die Installationsdateien sind jetzt aktualisiert.
Der Hotfix wird nur gebraucht, wenn Sie das Produkt vor dem 28.12.2013 im Classics Hangar Shop heruntergeladen haben.
Fw190D/Ta152H Service Pack 1
23. January 2014
Fixes and updates:
- inoperable cooling flaps handle in all Fw190D models fixed.
- reversed Fw190D-9 exterior paint schemes in 4096 pixel mode corrected.
- missing canopy sounds added.
- "cold and dark" switch added to the payload manager interface.
- multiple programming improvements in order to avoid event flooding issues.
This Service Pack is only required if you downloaded the Fw190D/Ta152 before 23. January 2014 at the Classics Hangar Shop.
If you added third party repaints to your Fw190D-9 or Ta152 models please backup your FLTSIM changes you've done to the corresponding aircraft.cfg files and reinsert them after the installation of the service pack as per the instructions of your repaint provider.
To obtain the service pack click on "Start/All Programs/Classics Hangar/Fw190D - Ta152/search for updates".
Alternatively you can re-download the complete package at the Classics Hangar Shop. To do so log in to http://www.classics-hangar.de/store with your user data, click on "Your Account" and download the installer again. Remove the old installation using the uninstall entry in the Start Menu\Classics Hangar folder before running the new installer.
23. Januar 2014
Neuerungen und Korrekturen:
- Inoperable Kühlklappenumschaltung in allen Fw190D-Modellen behoben.
- Vertauschte externe Bemalungen der Fw190D-9 im 4096 Pixel Modus korrigiert.
- Fehlende Schiebehaubensounds hinzugefügt.
- "Kalt und dunkel"-Schalter zum Beladungsmanager-Interface hinzugefügt.
- Verschiedene Optimierungen der Hintergrundprogramme, um "Event-Flooding" zu vermeiden.
Dieses Service Pack wird nur benötigt, wenn Sie die Fw190D/Ta152 vor dem 23. Januar 2014 im Classics Hangar Shop heruntergeladen haben.
Wenn Sie bereits Drittanbieter-Bemalungen zu Ihren Fw190D-9 oder Ta152 Modellen hinzugefügt haben, sollten Sie vor der Installation des Service Packs zunächst Ihre Änderungen der FLTSIM-Einträge an den entsprechenden aircraft.cfg Dateien sichern und nach der Installation wieder gemäß den Anweisungen Ihres Drittanbieters hinzufügen.
Zum Download klicken Sie auf "Start/Alle Programme/Classics Hangar/Fw190D - Ta152/ nach Updates suchen".
Alternativ können sie auch die komplette Installationsdatei erneut im Classics Hangar Shop herunterladen. Loggen Sie sich hierzu mit Ihren Zugangsdaten bei http://www.classics-hangar.de/store ein, klicken sie auf den Reiter "Ihr Konto" und laden die Datei erneut herunter. Deinstallieren Sie zunächst die alte Version über den Classics Hangar Startmenüeintrag und führen anschließend die neue Installationsdatei aus.
Ta152H Sound Fix
There is now a patch available that fixes the missing engine sound in the Ta152H-0.
This is only required if you are running the English language installation.
The German language version is fine and doesn't require the patch.
As usual click on
