Hi !
First of all.
Thank for a Very Nice Fw-190 A series.
Well - I have a small problem. I can´t use 3rd part paint, I have all black textures.
Have the download version of your Fw-190A Compilation, some of the early & late variants.
Must I have to bay the separate early and late variants ?
Best Regards
DennyBoy
Regard 3rd party paint addon
Re: Regard 3rd party paint addon
Hello Denny,
some things to keep in mind: repaints done for the early variants version 1.x are not compatible with the compilation.
Repaints done for the early variants 2.x and for the late variants should work with the compilation (granted it's the same sub variant, must be one of A-3, A-4, A-5, A-8 or A-9) but require a bit of special attention:
First create a texture folder inside the "target" plane according to the folder name of the downloaded repaint.
Next copy the entire content of a texture folder of one of the existing paints into this newly created folder.
Finally copy your repaint textures into this folder, overwriting existing textures.
This makes sure that you have all required textures and the proper texture.cfg in your new texture folder.
