Trouble Exiting the Sim!
Hello, I'm having a problem with the Bf 108v1.1. When I exit the screen, to return to the FSX start page, my computer tells me that a fatal error has occurred, and cannot complete this task. Is this a problem with the Loadout Manager?
Re: Trouble Exiting the Sim!
Not sure yet since it's the first report of that kind.
Did it happen just once or does it happen all the time?
Does it only happen with the Bf108?
It crashes after certain variables have been altered-In the main FSX start page, when the date and time, or weather have been entered other than the default settings. This happens only with my Bf 108. All other aircraft seem to work fine.
Ok, give me a bit, I'll try to dublicate the issue.
So far no luck dublicating the issue, everything's running stable as a rock over here.
However, let me talk to my SimConnect specialist if he can think of a possible conflict somehwere.
Perhaps nothing to do with it but....
try running FSX in Windows Xp Service pack 2 compatibility mode. I have been doing it for a month now and it never crashes anymore.
Hello. I just want to concure on the "exiting sim crash". I am getting this consistently if alterations via the new configuration popup are made to the plane. Sorry, I made multiple changes so I can't narrow this down. I will try a couple of test scenarios and let you know. I am running Win 7 64 and do not see any other aircraft exihbiting this oddity. I noticed it after upgrade to 1.1. Love the plane!!!! Great work.
Ray
Ray
There is a lot on Orbx forums about this.
Bottom line - FSX issue being overloaded.
I have no problem with my new PC with this plane - all works great.
