Messerschmitt Bf110 C and E
General discussion about Classics Hangar products
Helldiver
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Messerschmitt Bf110 C and E
Postby Helldiver » Fri 5. Jun 2009, 17:24
[b]Er,... Might it be possible that C9+AM in memory of Rudi Thun could be made of the antennaed aircraft?[/b]
Postby Mathias Pommerien » Sun 7. Jun 2009, 19:51
Hiya Helldiver,
we don't currently plan to do the nightfighters since the Zerstörer will keep us truely busy.
There's allready load of variations esspecially in the cockpits.
Just shying away a bit from making all that radar equipment, you know. :oops:
But I'm sure we can make a personal mokup wannabe Thun plan for you when time has come, just as we did years ago for you.
Helldiver
Postby Helldiver » Thu 11. Jun 2009, 22:32
Well that would be very nice of you.
By the way, our early radar om the SB2C had two scopes one for azimth and the other for elevation. Distance was a matter of interpretation. When the two points converged, you had collided with the target. Did the Luftwaffe had a similar setup? Just another duty the radioman/gunner, had including making sure the pilot didn't go to sleep.
When you both took a nap, then there could be trouble.
Huub Vink
Postby Huub Vink » Mon 15. Jun 2009, 12:45
Bob,
The nightfighters were equipped with different types of radar. The FuG202 which was often used on the Bf110 G-4 had 3 scopes; range, azimuth and elevation. The FuG220 however had only 2 scopes.
For further reading I can recomment this article:
http://www.cdvandt.org/Lichtenstein%20radars.pdf
Cheers,
Ian_Warren
Postby Ian_Warren » Mon 12. Nov 2012, 01:44
:D With the near closer and release of the D-9 , is a concerted effort be directed at our well known twin tailed BF-110 or has it gone on the back burner for a little whiles longer ? ;)
Postby Mathias Pommerien » Mon 12. Nov 2012, 06:49
Hey Ian,
I can't really think of any other excuse to further delay the Bf110 so it'll definitely be the next project after the Dora/Ta152 package has been released. :mrgreen:
Ian_Warren
Postby Ian_Warren » Tue 13. Nov 2012, 21:08
Mathias - Now that sounds like a deal to me :D With the reference below it would put many already in the seat , the idea and follies and also the funny characters .. but we do need a BF/ME-110 ;)
ZERSTORER GRUPPE a History 1939-1941 ,Author , Ludwig Von Eimannsberger , for anyone wanting to learn the life and times of a BF/ME-110 pilots and the unit Brilliant ! 50 % photos and text ... Quality print , A Schiffer Military History Book ..
eddie
Postby eddie » Thu 25. Apr 2013, 18:48
Well Herr Spock, or should I say Young Jedi, if you come over to the Dark Side and make the 110 G4, I will let you jam with me through out the Empire!! :lol:
Postby Mathias Pommerien » Fri 26. Apr 2013, 19:34
LOL, Scotty! :lol:
WarHorse47
Postby WarHorse47 » Sat 19. Apr 2014, 15:12
Curious.
Any progress on the Bf110? Is this still in the works??
--WH
Return to “General Discussion”
Who is online
Users browsing this forum: No registered users and 1 guest
