Atmospheric pollution
"Dora" Support Forum
william thompson
Postby william thompson » Tue 6. Oct 2015, 13:37
Greetings everyone, if anyone can tell me how to moderate the amount of smoke my Dora touchdowns make, I really need to know! Don't just tell me my landings are lousy, most of them are, but now and then I do achieve a nice three-point-no-bouncer, and when I look at the replay there's so much smoke that I don't know whether to laugh or cry. Is it possible to alter the effects file? I need to know. Think of the environment, guys, Cheers, william
Huub Vink
Re: Atmospheric pollution
Postby Huub Vink » Tue 13. Oct 2015, 16:36
Although I'm not an effects person, I assume the correct way to reduce the effect is to make the texture of the smoke more transparant, by darkening the alphas.
Cheers,
william thompson
Postby william thompson » Tue 13. Oct 2015, 17:11
Thanks, Huub, I'll try. I suppose the amount of smoke generated on touchdown was due to the type of material used for the tyres. Cheers, william
thunder100
Postby thunder100 » Sun 18. Oct 2015, 08:18
Hi William
I have a look into it
Some questions
Which Simulator?FSX P3D?
Only Dora or also TA-152
In which view its excessive to you?( you may think that it doesnt matter dut in MS FSX it matters )
Thanks Roland
thunder100
Postby thunder100 » Sun 18. Oct 2015, 08:53
Hi William
That effect is build in the model and triggered
So in oder to decrease that you need to ammend the aircraft.cfg of any D9(11-13-TA) you want to chnage that
Look for that
[effects]
startup=fx_engstrt-Dora9
and add
touchdown=fx_tchdwn,1
Then it looks like that
[effects]
SAVE
you can try as well
touchdown=fx_tchdwn_m,1//-->thats more
touchdown=fx_tchdwn_s,1// Thats the original one you deem too much
Hope that helps
Roland
william thompson
Postby william thompson » Mon 19. Oct 2015, 20:00
Greetings Roland, I am using FSX with Acceleration, the smoke occurs on touchdown with the Dora, when I review my approaches and landings in Instant Replay. I have not yet flown the TA-152, but I will try it. Thanks for replying, Cheers, william
william thompson
Postby william thompson » Thu 22. Oct 2015, 14:12
Greetings Thunder100 and Huub, my Dora 13 landings are smokeless now, [though still far from perfect in other respects], and I want to say that I really appreciate your responses to my appeal. Thank you, Gentlemen, and Best Wishes, william
Return to “FSX Fw190D/Ta152”
Who is online
Users browsing this forum: No registered users and 1 guest
