Trying to install an autopilot for both Ta 152H, I observed the following increments :
Heading increment : 10°
Altitude increment : 300 meters (+/- 1000 feet)
With all FW 190D, the system correctly works :
Heading : 1°
Altitude : 30 meters (+/- 100 ft)
Is there a solution to fix this ?
Thank you for this very exciting aircraft.
LGW-Siemens K 23 autopilot
Re: LGW-Siemens K 23 autopilot
Hi Fulbert,
we identified a problem with the Ta152 that causes a number of actions to perform faster by a factor of 10.
Amongst them is the autopilot action you describe, setting ADF frequencies as well as trimming the aircraft.
We are working on a patch.
Thank you very much, Mathias !
