JonP01 wrote:Hi,Mathias Pommerien wrote:Oldendirt, you don't need to edit anything by hand.
This time around the included tool will adjust the FSX.cfg (if needed) and do the texture configuration.
It's located at
Start\All Programs\Classics Hangar\Bf 108 Taifun
along with user manual, just fly utility, "check for updates" link and some other shortcuts.
I am just curious - what line in the fsx.cfg file does the tool change? I selected 2048 to begin with and looking at my fsx.cfg file afterwards, I could not see what it had changed.
Jon, it does two thing:
1. It configures the texture.cfg files in the Bf108 aircraft folders to use the resolution you choose.
2. It looks into the FSX.cfg, checks the texture_max_load and if required adjusts it as per your selection.
That means in return if you select "2048 in the manager and your actual value in the FSX.cfg is allready 2048 or higher, it won't do anything.
