Prepar3D and the 190
Posted: Thu 12. Sep 2013, 18:46
by william thompson
Greetings, All, and wonder if the 190 will run in Prepar3D?
Thanks and best wishes, william
Re: Prepar3D and the 190
Posted: Fri 13. Sep 2013, 05:19
Hi William, I don't see why it shouldn't work.
The showstopper will be the installer though which won't install into P3D so you would have to copy the files manually from FSX.
Well, there was no p3d around when we made the 190. We'll keep that option in mind for a possible Fw190 update.
Posted: Sat 28. Sep 2013, 20:06
by william thompson
Thank you, Sir. Best Wishes, William
Posted: Sat 28. Dec 2013, 20:20
by william thompson
Greetings, and with the Estonia migration tool the 190 installed without difficulty into Prepar3D. A great aircraft, but rather a pity that there are no radio aids [apart from the ILS] for the low level cross country enthusiasts. Or is there one I have not been able to find? I hope there is, it would make the perfect package. I have tried unsuccessfully to install an ADF which would have done the job brilliantly. Oh well, into each life a little rain must fall!
Best Wishes, everyone,
william
